what are these sensors and connectors?
Old Oct 16, 2011 | 01:48 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
question on a couple sensor/connectors.
this sensor goes to my trans
and this is the connector
what is it? it wasn't connected before i even removed anything.
and this sensor is on the passenger side between the exhaust header
and here is connector
wtf is that? can't be a temp sensor cause that's on the other side of the engine.
Old Oct 16, 2011 | 01:54 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: what are these sensors and connectors?
Pic #3 is the fan temp switch, but some of it is missing. The connector for that one should look exactly like the connector for your knock sensor, which is located low on the passenger side of the block near the middle.
Old Oct 16, 2011 | 01:59 PM
Twin_Turbo's Avatar
top = TCC lockup, the connector in pic 2 goes in it
Old Oct 16, 2011 | 02:13 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Auto transmissions aren't my thing, but the wiring diagram shows a tan/black and pruple for the locking convertor, and the green is the 4th gear switch.
Old Oct 18, 2011 | 09:47 PM
Engine: 350 L98/LS2
is there a good site or picture somebody has of L98 engine bay sensors/connectors? there's a connector at the back of my engine that i don't know where it goes. just did a recent engine pull with some friends so i didn't unhook everything.
Old Oct 18, 2011 | 10:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by blackbeauty89
is there a good site of L98 engine bay sensors/connectors?
Look here under TPI
http://www.eficonnection.com/eficonn...ngineType.aspx
Old Oct 18, 2011 | 11:59 PM
Engine: 350 L98/LS2
thanks man. nice site.
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
