pressing ps pump pulley back on question.
Old Oct 22, 2011 | 12:15 AM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
i'm attempting to press my ps pulley back on on my L98. it isn't working so well. i have the correct tool to do it, but it won't thread in the shaft and it also messed up the threads on the tool. so how do i go and press on this pulley?
Old Oct 22, 2011 | 02:06 AM
Engine: 350 L98/LS2
Re: pressing ps pump pulley back on question.
anyone?
Old Oct 22, 2011 | 02:20 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Are you sure your using the right threaded rod? Unless the threads are fubar from a past repair or severe rust, it should thread in with ease. If youve stripped the threads in the shaft already, then its time for a fresh PS pump. You might be able to helicoil it if your careful, but a new pump might be easier in the long run.
If the threads are still there, but damaged, you might be able to chase them with a repair tap and clean the first few up. I dont recall what the threads are off the top of my head, but I think it was something fairly common like 3/8"-16.
Old Oct 22, 2011 | 09:41 AM
Engine: 350 L98/LS2
i'm pretty certain it's the correct tool. and it does seem to look pretty rusty in there, i'm really hoping i can just repair the threads, i need this car moving tonight
evilstuie
Jan 9, 2020 08:29 PM
Navy8125
Aug 22, 2015 07:13 PM
mcquigg
Aug 13, 2015 02:26 PM
Street Lethal
Aug 12, 2015 11:33 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
