Need help, about to junk it lol
Old Oct 23, 2011 | 12:51 AM
Jason500k's Avatar
Hello, I'm new on here. I just bought an 87 camaro 2.8 5speed, and it will not start. I have replaced the fuel pump/filter/distibutor/wires/sparkplugs/egr/vac lines/fuel filter/ign coil/iac/iac plug/almost all gaskets/oil pressure switch/maf/ maf relay/battery/ and have reset the timing. but now it wont start at all. To give you an idea of whats happened, it use to hesitate really bad and would only run at high rpms, then it died on the freeway on the way home at 70 mph. and now it just sits in my drive way. Im seriously about to take a sledgehammer to this car..... One thing is that i have no fuel pressure when i push on the shraeder valve. the pump primes everytime i turn the key but it wont start. I have jumped it on the fuel pump relay plug and it still wouldnt start. please help... because im loosing faith in camaro's from this experience..
Old Oct 23, 2011 | 09:06 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Need help, about to junk it lol
If you put a new fuel pump in it and the pump runs there, should be fuel at the shrader valve. If the fuel pressure regulator is open it will just free flow back to the tank without building pressure. If you can take loose the return line (smaller of the two) and verify flow (into a pan) when the pump runs, then the fuel pressure regulator is bad.
Old Oct 23, 2011 | 09:10 AM
3rdGenMess's Avatar
Car: 1990 RS
Engine: SBC 350 YearOne Crate
Transmission: T56 (LT1)
LOL! you know im having the same problem with my 350, i did a transmission swap; 700r4 to a t56 and soon as i brought the car back it didnt start anymore...every one that i talked to said something about the timing "jumping" or the engine "jumped timing" meaning the chain rotated off the sproket throwing it out of sync...im sure if you fix that problem you will fire up just fine atleast i hope cause i gotta try the samething, so i guess you can keep me posted as well so ill know if it works...lol.
Old Oct 23, 2011 | 09:43 AM
Jason500k's Avatar
Well i hope its just the fpr but who knows.... ill try and see if it is the fpr and keep you guys posted. thank you for your replys but if neone has ne other options lmk.
p.s. i did forget to mention when i do push on the valve gas just overflows out of it instead of shooting up. didnt know if that would help anything///
Old Oct 23, 2011 | 10:28 AM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
did you replace all that stuff chasing down this problem?
That's a lot of money to throw at a no start issue. Did you have similar fuel pressure before changing the pump?
You are correct about the squirt rather than trickle from the schrader valve.
Should be at least 1 big spray after priming. Are you sure you have spark and no fuel?
Old Oct 23, 2011 | 11:02 AM
Jason500k's Avatar
ya i did lol, cheked for spark and was blue. here shortly im gonna take off the fuel filter and see if its clogged and if im getting pressure out of the tank.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
