1992 camaro rs won't start
Old Oct 25, 2011 | 07:31 PM
Simmbad's Avatar
Car: 1992 camaro rs
Engine: 3.1v6
Transmission: 5spd
Hello all,
I have a 1992 rs 3.1 v6 5spd camaro that has sat for the past 11 years, the car ran when parked, just needed a big car for the family now I want it back on the road.
I have drop the gas tank drained all the old fuel out and replaced the fuel pump at the same time, I have bleed the fuel lines of all the old fuel using the prim jumper.
I have had the fuel injectors checked and cleaned by a shop.
So here is the problem. The car turns over but dose not start also can't hear the fuel pump running, (it run if you use the prim wire) if I spray starting fuild into the intake the car fires up then dies.
I thought it might be the v.a.t.s, so I bought a bypass chip, but when I was looking for a hot wire on the ECM, I found that none of the organge wires that are suppose to be hot had power. I checked the fuses all are good.
Is there a relay or something else that sends power to the ECM? I have check the Manuel's but don't see anything.
Thanks for any help
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
