vac
Old Nov 10, 2011 | 08:26 PM
BillyBLKPearl91's Avatar
Car: 91 camaro rs
Engine: 305 carb
vac
behind the carb is a intake vac were do I connect it to does any one have a good diagram or pic Or a good example on were it should be connected to any please...and can this be the reason the car smells like gas after it sits for a little bit
Old Nov 13, 2011 | 02:39 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: vac
If you're talking about the big threaded vacuum port on the back of the carb, it goes to the brake booster.
The type of carburetor would be extremely helpful; '91's didn't come from the factory with carbs at all.
Old Nov 13, 2011 | 09:09 PM
Car: 91 camaro rs
Engine: 305 carb
Re: vac
it is not on the carb is behind it is on the intake manifold
pjsparts
Oct 29, 2025 06:39 PM
Mark_ZZ3
May 24, 2018 01:02 PM
69GTOby
Apr 18, 2016 02:34 PM
92-Formula
Dec 12, 2015 10:34 PM
Reid Fleming
Oct 10, 2015 09:56 PM
