do i need a new fuel pump
Old Nov 19, 2011 | 03:51 PM
BftCamaro's Avatar
Car: 1987 camaro Z28
Engine: 5.0 TPI LB9
Transmission: 700r4 auto
Axle/Gears: 2.62:1
so my camaro will shut of in the middle of the road sometimes but will start right back up after like 10 mins and when i hit the gas pedal the car doesn't accelerate right it will go real slow until i finally get around 40 mph. but when i stop at a stop sign or a red light it just does it again. I think i need a new fuel pump and a new icm am i right.
Old Nov 20, 2011 | 03:38 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: do i need a new fuel pump
Can you tell us some specifics like engine size and whether it is carbureted, TBI, or TPI?
Old Nov 20, 2011 | 04:28 PM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
well it is a 3.1 v6 191ci motor and idk what tbi or tpi means
Old Nov 20, 2011 | 04:40 PM
jtsk's Avatar
TBI = throttle body injection and TPI = tuned port injection. Being it's a 3.1 you probably have injection of some sort, but not TPI. Don't know much about the V6's, but to rule out the fuel pump, disconnect the fuel line from the engine and attach a pressure gauge and check it. The correct pressure you can find in a service manual or a Chilton's or Haynes manual. If you don't have one of those, I recommend getting one. You can pick them up for about $20 at your local auto parts supplier. Could also be a fuel pressure regulator.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
