fuel pump removal
Engine: 4++,350 & 305 CIs
Re: fuel pump removal
Yes, I'm not a fan of it at all..
Use the search feature and you will find plenty of bickering about hack jobs.
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Drop the rear and take it out the bottom. If you cut an access door, you'll also need to cut all the lines when pulling the pump.
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
The answer is yes. Please use the search. I don't say that to sound rude, I want to prevent the 600 reply battle that this question always creates. It has been done, it's up to you to decide if it's the way you want to do it.
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Don't cut an access panel!!! It weakens the body/frame structure. It is best to remove exhaust and lower the rearend. It takes about 8 hours to do the job. You will have regrets if you cut a access hole. Rust in the tank can cause a fuel pump to quit. Do it right and remove the fuel tank and wash it out with a pressure washer. Make sure all lines are free flowing. My return line was stopped up with rust from the fuel tank. Make sure you inspect the contacts for the fuel guage sending unit and clean as needed.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
