Fuel system hissing noise
Old Dec 12, 2011 | 07:00 AM
markmutko's Avatar
I went to pep boys and got my car diagnosed 90 chevy convertible 5.7. They said was the it the fuel pump and the sending unit, I replaced both of these but now it is losing pressure from somewhere, I think it coming from the locking cap or fuel tank might be leaking. Is there a pressure test you can perfrom on the tank to find out which one it is losing pressure?
Old Dec 20, 2011 | 09:51 PM
mechanic1992's Avatar
Car: 1987 IROC-Z
Re: Fuel system hissing noise
not in the tank, check your fuel pressure regulator, fuel filter. make sure the fuel pump is actually pumping and try and see if your lines could be clogged. how did you realize you are losing pressure? Your injectors might not be opening all the way causing a restriction and drop in pressure.
theshackle
Sep 17, 2020 08:26 AM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
