L98 Swap help please
Old Dec 19, 2011 | 04:19 PM
Camman9167's Avatar
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
Hi everyone im doing my first build for my camaro getting rid of the old shity 305 and i just acquired an l98 it needs total overhaul. Im thinking i might do a turbo set up, what are suggestions on bottom end parts....also im having it bored .30 over as part of the clean up. Im thinkin about doing a tpi set up, but not sure if that would be wise over doing carbs with efi.
All thoughts and suggestions are welcome im learning as i go
Old Dec 19, 2011 | 04:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: L98 Swap help please
Budget ?
Old Dec 27, 2011 | 12:11 PM
Camman9167's Avatar
Car: 1991 Camaro RS
Axle/Gears: Factory
taking my time to build it, i would imagine 3-5k in the long run
Old Dec 27, 2011 | 12:17 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
well if your going to turbo it i suggest a forged bottom end. eagle and scat both make nice rotating assemblies... mine rotation kit is made by eagle and the forged pieces are top quaility but my kit was around 1600 dollars.. since you need to replace everything minus well get a 383 kit... they are about the same price as a 350 or 355 kit so minus well go for the extra cubes...something along with 8.5 to 1 compression with a turbo would be good....
Old Dec 28, 2011 | 08:17 AM
Camman9167's Avatar
Car: 1991 Camaro RS
Axle/Gears: Factory
I have heard that eagle cranks have been known to snap, how has your experience been with them? i assume great since you suggested it, but other than the crank issue i havnt heard anything bad about eagle
lt500r55
Sep 1, 2021 01:30 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Hello, Michael
Aug 20, 2015 03:19 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
