Rust in fuel tank - advice please!
Old Dec 28, 2011 | 03:21 PM
Berthold's Avatar
I just got the tank dropped on my '86 v6 MPFI and this is what I see
https://www.thirdgen.org/forums/atta...1&d=1325107181
So I figure I need a new fuel pump assembly (is this called the sender?) and tank.
Questions:
1. Ac Delco fuel pump assembly?
I already have a new Ac Delco pump and strainer. Will this assembly do from Orielly if I swap out the pump? http://www.oreillyauto.com/site/c/de...aro&vi=1035560
2. New tank, or can the orginal be restored? Where to get a new/restored tank? Orielly tank here:
http://www.oreillyauto.com/site/c/de...00/GM2721B.oap
3. What should I do to the rest of the fuel system given the rust in the tank?
4. Any other input?
Old Dec 28, 2011 | 07:59 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Rust in fuel tank - advice please!
Do a quick search on the spectra tank.
I'm on my phone so I can't help.
Spectra has more problems fitting than no problems.
IIRC,
The fill neck is angled wrong, & cutting it at a certain place will help get the tank in, then you have to figure how to angle the cut piece to fit correctly, then get together.
Sure there a few, VERY few had little or no problem.
IDK about the Spectra sending unit.
JCWhitney has a selection too, look there for a sending unit. IIRC, $ stats around 140 or 150.
IDK what their brand is, sorry.
( edit )
https://www.thirdgen.org/forums/afte...-gas-tank.html
Old Dec 28, 2011 | 11:29 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If the filler neck is cut and rotated out of alignment the burp tube will need to be somehow reconnected so that it can still be functional. The burp tube relieves pressure that can interrupt fueling.
If you get a tank that actually fits be careful not to stress the filler neck, doing so can cause the soldered connection at the tank to crack and allow air & moisture to enter and corrode the tank ruining tank and sender as well.
Old Dec 28, 2011 | 11:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Mureatic asid and then do a tank coating look at Eastwood products.
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
