fuel pump howl? video. vapors?
Old Jan 9, 2012 | 07:28 PM
1roc89z28's Avatar
i was driving the whole day. then as im driving down the freeway today on a hot day . my rear seemed like it was howling. so i decided to record it, once again.http://youtu.be/aXrdNPdezmg
i took the gas cap off and air preassure came out. its normal, but not like today it was bad. u can even see the gas vapors for a long time. look at video carefuly plz. am i driving a timebomb? or poison?http://youtu.be/nzW4gNcZ0vA
also i turned on the switch to hear fuel pump, an it sounded realy realy loud. no normal at all. i could hear it from a mile away http://youtu.be/JZkYWZMyQmE
Old Jan 9, 2012 | 07:54 PM
m16a2r's Avatar
Car: 1988 Pontiac GTA
Transmission: 700r?
Re: fuel pump howl? video. vapors?
have a similar problem, too much pressure in the gas tank, my guess is that fuel lines clogged up, I put 2 cans of seafoam in, so far so good
Old Jan 11, 2012 | 01:48 AM
1roc89z28's Avatar
2 cans of seafoam a little extreme dont you think
Old Jan 11, 2012 | 02:21 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
doesnt this mean that youre fuel pump is going bad...? my car does the same thing, moreso in hot weather than in the cold.
Old Jan 11, 2012 | 02:28 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Mine does this as well, it's even scarrier when you're filling up after driving for a while, the pressure builds as the gas enters and it sounds like it's going to start spraying everywhere or explode.
Old Jan 11, 2012 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Seems to be a common issue lately. Check this thread on the TPI board:
https://www.thirdgen.org/forums/tpi/...regarding.html
RBob.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
