Run ning a carb in the snow
Old Jan 17, 2012 | 01:29 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Hey i have a carb'd 87 305 and yesterday it snowed here so naturally i took warmed it up and took it for some driving. It didnt want to idle right after a few minutes of running, and when i got on it and revs hit prob past 3500rpm it would occasianly act like it wanted to die. It felt like the car gasped and lost all rpm, then came alive again a second later. It runs fine normally, is it the too dense or moist air?
Is it bad to run my carb in the snow? thanks
Old Jan 17, 2012 | 04:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd try to keep the snow out of the carb...
If it's bad to run a carb'd car in the snow, then we've had many millions of bad people for the last hundred years or so...
Is your choke light coming on? Does your choke light work?
Do you have the factory air cleaner on the car? If so, is the air cleaner missing any parts?
Old Jan 17, 2012 | 04:22 PM
Car: White 84 z28
Engine: Chevy 350
Re: Run ning a carb in the snow
Has aftermarket air cleaner on it that to my knowledge is installed right. And never heard of a choke light.
Old Jan 17, 2012 | 06:41 PM
five7kid's Avatar
Factory carb'd cars have a choke light in the dash. You may have never noticed it, or the bulb may have burnt out.
Factory tune isn't all that happy without the thermovac function. Not necessarily as you described, though. The transition from cold & choked to fully warmed and choke open, coming off idle, is where the problems really show up.
Old Jan 17, 2012 | 07:09 PM
86_sportcoupe's Avatar
Car: 86 Camaro Sport Coupe
Axle/Gears: stock
somethings not right. ive ran my car all winter so far and i haven't had any problems other then it takes a couple seconds to idle properly on a cold start. oh by the way i have a carbed lg4
Old Jan 17, 2012 | 07:55 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Does it run ok once its warmed up? Or is this something thats become a continuous problem?
The aftermarket air cleaner- I would double check that it was installed correctly. make sure everything is in good shape and everything that needs to be hooked up is hooked up. Something else that may be a good idea, try re-installing the original one and see if it helps. You never know!
EGR?
Vacuum leak?
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
86IROC112
Aug 17, 2015 02:00 PM
GVMV
Aug 16, 2015 08:01 PM
