HELP!!!!!
Old Jan 20, 2012 | 06:40 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
HELP!!!!!
Soooo yesterday my car started acting like it was out of gas, so I filled it up and it only took 10 gallons(my gas gauge doesn't work), then it would start but wouldn't run so I started and reved it and it acted fine so started driving home and it started acting like i was giving it gas hard then letting off when I had it about 1/4 throttle, and everytime I stopped I had to keep starting it up over and over again but after awhile it smoothened out and just ran rough and really rich
Any suggestions???? One of my buddies said it could be the fuel pressure regulator but hes been wrong before
Old Jan 21, 2012 | 09:44 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: HELP!!!!!
We need to know more about your car.
Have you replaced the fuel filter? Have you checked the fuel pressure at the rails? Have you ohmed the injectors to make sure they're good?
There's alot you can do, we just need to know a bit more about your car before offering advice. On a side note, my car does that occasionally, the throttle seems to stick open and run wild to 6K RPM, only way to get it to stop is to shut down the motor. Took my carb off and cleaned it really well, seems to have fixed it but was still wierd.
Old Feb 15, 2012 | 09:25 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Re: HELP!!!!!
Sorry it took so long but its an 88 TA tbi and it has a newer fuel pump, fuel filter and fuel pressure regulator and the last I checked a couple weeks ago it was at 11psi or so. It started acting up today again but only I drove around for a couple hours and parked it. It acted as if it was out of gas, but eventually it stayed running long enough for me to take off and then there was no problem other than it running warmer than usual and pretty rough
I haven't yet ohmed the injectors tho
Old Feb 15, 2012 | 09:29 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: HELP!!!!!
Sounds like the TPS.. I had same problem and changed mine, was good to go!
Old Feb 15, 2012 | 09:32 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Re: HELP!!!!!
I had replaced the tps sensor when I did the fuel pump, do u think its not adjusted right?
