several noob questions
Old Jan 27, 2012 | 03:14 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
So I got a set of pro topline srt heads. Used but low miles. Anyways they don't come with pushrods or rocker arms. How do I pick the right ones. Also while I have heads off what else should I give attention to. And should I bring heads to machine shop to have them check valves and such. And if so how much should I expect to pay. These heads are going onto my carbed 327. And right now I have some 882s. Will I notice a difference with theses heads. They have 167cc runners, 64 CC combustion chamber and are 1.94/ 1.50
Old Jan 27, 2012 | 03:52 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: several noob questions
Always a good idea to check for an even flat surface.
If in doubt, check for bent valves.
For push rods, you will have to know the cam lobe lift & spring pressure--
--max lift to bind & install height.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
