Hooker 2055 - spark plug wires?
Old Jan 28, 2012 | 08:29 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Can I use regular straight ac delco spark plug wires with these headers?
Old Jan 28, 2012 | 07:51 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: Hooker 2055 - spark plug wires?
Most likely,no.I've seen very few SBC headers that didn't require 90* plugwires.
Old Jan 29, 2012 | 09:05 PM
phaller13's Avatar
your better off buying a set that you can custom make on your own
Old Jan 29, 2012 | 10:57 PM
bmorgil's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: Chevy 383 Stroker
Transmission: Probuilt 700 R4
Axle/Gears: 3.73 with a Detroit Locker
Probably not. But all is not lost. Use the new 90 deg. ceramic booted wires at the plug. This is the best choice for gen 3's because it is so tight in a gen 3 with the hookers that you will eventually fry any other boot material. Now you still have one issue. The fit between the header primaries and the plug gets so close in a few cylinders that you may not get a full length plug (depending on your heads) in and get the boot on. If you use a high dollar iridium NGK plug or similar precious metal like platinum, they will last well over 100,000 miles without issue. Just remember you may have to put the plug and wire together with the headers off or pulled away as far as you can. You can bypass this issue with an Accel Shorty plug however, they will need changing as the gap increases. I use the ceramic boots with NGK iridium plugs. All wires are shielded completely with msd high temp covers and run under the headers against the block and up the back of the heads with a small diameter distributor cap and external coil instead of over the valve covers. This produces a clean look. Several motors running around this way. With this set up you probably will never have to mess with plugs and wires again. In general Hooker's usually fit very well.
Hope this helps you,
Bob
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
