new balancer cover timing
Old Jan 29, 2012 | 08:13 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i bought the harmonic balancer cover that has all the engravings on it, my question is when i set up my ignition timing am i supposed to use the 0 mark on the timing tab to line it up with the 10* mark for my base timing? im a little confused about it.
Old Jan 29, 2012 | 09:03 PM
Damon's Avatar
Re: new balancer cover timing
Yes. If you have a degreed balancer then you use the 0* (TDC) mark on the tab as your reference point to measure against the timing lines on the balancer. Factory stuff works exactly the opposite.
Old Jan 30, 2012 | 10:22 AM
Engine: 355
would 10 or 8* be better for a 355?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
NBrehm
Aug 25, 2015 11:49 PM
