Need help PLEASE
Old Feb 2, 2012 | 10:09 PM
bryans88bird's Avatar
Car: 1988 PONTIAC GTA TRANS AM
Engine: 305 TUNED PORT INJECTED
Transmission: T5 BORG WARNER 5 SPEED
Axle/Gears: 3.45 Positrac
Need help PLEASE
Still having a hard cold start on my gta 305 tpi. I need this car to start reliably so I can drive it. Problem I'm having is when the car is bone stock cold it will not start if I spray starting fluid in it she fires rite up! I have had the 9th injector totally cleaned and rebuilt I have put a new fuel pump, fuel filter, fuel pressure regulator, fuel pump relay new plugs and wires I just don't get it when I get it running she runs like new so weird please help me out
Note: car has 200,000 miles on it
Old Feb 3, 2012 | 07:06 AM
ex-x-fire's Avatar
Re: Need help PLEASE
You need to check to see if the 9th injector is being activated electrically.
Have you check the fuel pressure? I know everything is new, but you don't know if its leaking down if you don't check it.
Old Feb 3, 2012 | 08:57 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The brass switch in intake on the left is the CSI switch.
Should have 12V to it and out of it to CSI when cranking engine over cold (only )
Old Feb 3, 2012 | 11:51 AM
OK thanks guys I'll try those and get back to you
