quick firebird question
Old Feb 11, 2012 | 11:19 PM
88cam23's Avatar
I have a chance on picking up a cheap 1987 firebird with a 2.8 do the ecm and motor parts interchange with the 2.8 from a 88 camaro?
Old Feb 12, 2012 | 07:46 AM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: quick firebird question
they should. check the ecm number in each car, assuming you have the ecm from the 88 to compare with, but it should be the same.
Old Feb 12, 2012 | 08:15 AM
ex-x-fire's Avatar
They had some oil pan/timing cover differences in those years. But everything should swap over if you have to.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
