Same dumb question!
Old Feb 12, 2012 | 11:25 PM
zzjakect's Avatar
Car: 1985 Z28
Same dumb question!
Where is the fuel pump relay and how do I test it? I put in a new fuel pump, but it still does not provide any gas to engine. I guess the other item is where is the fuel filter? I think I should replace that as part of this issue. 1985 Z28 with an automatic and 350 motor from who knows where is what I'm dealing with. I appreciate any advice you can provide.
Old Feb 12, 2012 | 11:43 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Same dumb question!
Did you check the fuses? relays are on the driverside firewall by the brake booster and the ECM fuelpump fuse is close to the battery with a orange and red wire going in the bottom.
Also get a service manual from helm, Inc. worth every penny
Old Feb 12, 2012 | 11:53 PM
zzjakect's Avatar
Car: 1985 Z28
Thanks so much! I'll invest in the helms manual. I'm sure I'll get a lot of use from it.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
