A.I.R Injection Lines to Cats - How factory attached??
Old Feb 14, 2012 | 12:33 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
How is the A.I.R Air injection tube that hooks from the air pump to the Catalytic converts attached? I am ordering a new A.I.R line as mine broke and cannot be fixed.
I run my car without the 2 cats and was thinking that IF the line to the airpump is THREADED and if the other two ends are threaded (perhaps they thread to the FACTORY CATS as apposed to the WELDING for universals and aftermarket cats).
If the lines are threaded, when I take OFF the cats (after passing emissions testing each 2 years) rather than having 2 lines dangling and smacking against the frame that perhaps I could simply UNSCREW IT the line to the A.I.R pump, and UNSCREW it (would involve making threads in the Air lines that come out the 2 cats but should should not be a problem) from the two high-flo cats.
Right now the cats are flanged onto the exhaust so they can be easily removed, not so with the small air lines. Plus once the Straight thrus are replaced for the cats for normal driving, the now unattached air lines end up vibrating and banging into the frame of the car.
Old Feb 14, 2012 | 01:07 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: A.I.R Injection Lines to Cats - How factory attached??
I can't be sure the ones I have seen are original, but pretty sure they were welded from the factory. If you are just looking to attach the pipe without concern to originality, you can use a connector pipe w clamps or there is a special heat resistant hose available at Napa which can be used to connect the pipe to cat inlet, again with clamps.
Old Feb 14, 2012 | 01:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The AIR system isn't doing anything during test conditions anyway.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
transaero
Aug 31, 2015 01:14 AM
