COMPRESSION QUESTION/PROBLEM
Old Feb 16, 2012 | 02:29 PM
badmoon47's Avatar
Just ran a compression check on my TPI 305 and wanted some input.
The engine is 2 years old. I assembled it myself. New block, aluminum cylinder heads, ect. Since I installed it, it has always had a slight part throttle miss and used coolant (a couple of ounces every few hundred miles or so). No exterior leaks or white smoke out the tailpipes. I rented a compression tester from AutoZone today hoping it would shed some light on things. The test was done with all 8 plugs removed and the throttle held wide open. Due to unfriendly header pipes, I only got 5 of the 8 cylinders tested, but I think the results on the 5 I did get speak for themselves.
# 1 - 99 PSI
#2 - 106 PSI
#3 - 101 PSI
#4 - 100 PSI
#5 - NA
#6 - NA
#7 - 98 PSI
#8 - NA
From other posts I hear cylinder pressure should be from a low of 135 PSI all the way to 180 PSI. These all seem WAY low to me. I am thinking I have used the wrong type of head gasket. Any input would be appreciated. Thanks!
Old Feb 16, 2012 | 05:58 PM
ex-x-fire's Avatar
Re: COMPRESSION QUESTION/PROBLEM
Yes they are low. You might need to do a leak down test, far more useful. Did you use 350 heads on that 305? Maybe they have large chambers.
Old Feb 16, 2012 | 06:03 PM
badmoon47's Avatar
They are Trick Flow aluminum heads for the 305. They have 56cc chambers and give me a CR of about 9:1. I used head gaskets suggested by the Summit Racing tech line. Maybe they are the wrong ones. I'm just fishing for some input before I tear into this thing. Thanks for the reply!
Old Feb 16, 2012 | 06:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The absolute pressure value is virtually meaningless. The relative values between cylinders are what's important.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
