Fuel tank problem... runs out at half a tank
Old Feb 17, 2012 | 11:13 PM
VandykeT/A's Avatar
I've got a 89 Iroc that I just ended up with today has a problem with the fuel tank. The gas hand shows full all the time. Well it ran out in the driveway so I got a gallon of fuel and poured in it and then drove next door to the gas station (convenient right lol) and the car only held 6 gallons I added until it ran out the top. Well I pull back over to my house and they're probably a 4 x 4 foot puddle of fuel under the car. What would cause this? I just don't understand the running out of fuel at half a tank. Thanks
Old Feb 18, 2012 | 11:57 AM
mrrman's Avatar
Re: Fuel tank problem... runs out at half a tank
Could be a faulty sending unit...had the same issue in my TA, replaced the sending unit anf fuel pump and its now okay
Old Feb 18, 2012 | 04:22 PM
VandykeT/A's Avatar
So it caused the car to run out of gas at half a tank?
Old Feb 18, 2012 | 07:01 PM
mrrman's Avatar
If your fuel gauge is reading wrong then it could be a sending unit issue
Old Feb 20, 2012 | 12:43 AM
VandykeT/A's Avatar
Well I figured out my problem. The failing to start wasn't actually the fuel. The gas hand doesn't work but when the car failed to start back I started it a few times one right after another. The coil was actually the problem. Thats why it started after I put gas in it. It had 15 minutes to cool down. It did this to me again after being moved very short distances ( in a garage with the door shut). I checked to see if I had spark to the number 1 plug and didn't. I then took off the coil wire and still nothing. Waited 5 minutes and it fired up. I guess constantly firing and stopping caused it to get hot and stop working. The car also had a pulsating idle. Like from 550 to 700 it seems to have stopped now. I still have a tank/gauge issue but it wasn't what kept it from running. Thanks guys.
Old Feb 20, 2012 | 12:50 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I have a question you said gas was on to the ground, where was it coming from? The gas nozzle hole?
Old Feb 20, 2012 | 01:01 AM
VandykeT/A's Avatar
I'm not sure. I filled the car up until it ran out the neck and pulled it less than 150 feet to my house. The leak is more toward the driver side so its possible that it pushed back through the fill hole.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
