Return fuel line in sumped tank
Old Mar 2, 2012 | 12:23 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Hi, Ive got a sumped fuel tank, with 2 outlets. 1 im using for the flow out. The question I have, is can I use the other outlet for the return? Or is putting fuel back under the pressure of the weight of the fuel in the tank going to cause a oroblem? I dont think I can get a -10 AN fitting in the top?
Old Mar 2, 2012 | 07:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Return fuel line in sumped tank
Personally i don't see a problem as far as pressure goes.
My concern would be returning warm fuel immediately adjacent to the sump pick up point so possibility of raising fuel temp to rails; most likely with extended driving , not a short burst down the strip
I have seen small coolers on the return line installed to get airflow under rear to cool fuel before it gets to tank
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
