Throttle Response
Subscribe
Mar 12, 2012 | 06:43 PM
Ok so i got a 1991 camaro v6 3.1.
i noticed over time that once im riving the car around for about 20 minutes or on the freeway, me throttle responce is slow. i push the gas and about 2 seconds later it kicks in. what can be causeing this?
Reply 0
Mar 13, 2012 | 12:39 AM
Re: Throttle Response
any trouble codes?
Reply 0
Mar 13, 2012 | 09:04 AM
no, just a steady code 12
Reply 0
Mar 13, 2012 | 12:22 PM
When you step on the pedal, does it stumble or hesitate before getting up and go, or is it just steady "vrrrrrrrrrrr" and then ?VVVVVVRRRRMMM"?
Reply 0
Mar 13, 2012 | 04:40 PM
like im in third right. so i push the throttle all the way, and i dont feel much difference then when i barely push the throttle. also when i do it with my hand ( pop the hood and push the throttle down) its slowed by about 1 second.
Reply 0
Mar 14, 2012 | 08:37 PM
That's a confusing situation. I have no idea what kind of system you have. If you had a TPI, I could of directed you in a better direction. Sorry man.
Reply 0
Mar 14, 2012 | 08:44 PM
no problem man, i guess i shud have put this in the v6 but idk how to get to the v6 forums.
Reply 0
Mar 15, 2012 | 10:38 PM
Quote: no problem man, i guess i shud have put this in the v6 but idk how to get to the v6 forums.
How hot is the car?? Like 220 degrees or so?
Keep in mind its only a 140hp car and the throttle responce isnt great when you just mash the gas all the way. Video tape it and I can see if its about the same as mine was when my car was stock.
Id go video tape mine and show you what mines like, but I totally fried my stock fuel pump the other day...opps I guess that happends with 30lbs injectors and a tired fuel pump.
Reply 0
Mar 15, 2012 | 10:54 PM
:0 aw crap. so ur car is standing atm? ok i will do it tommorow asap
Reply 0
Mar 16, 2012 | 07:12 AM
Quote: :0 aw crap. so ur car is standing atm? ok i will do it tommorow asap
Yea till I get a better fuel pump in a few days. Walbro 255. And it is no fun taking out the old fuel pump im told. This should be fun
Reply 0
Mar 16, 2012 | 08:24 AM
Keep an eye on the brake lines when you drop the axle.
Reply 0
Mar 16, 2012 | 04:34 PM
Quote: Keep an eye on the brake lines when you drop the axle.
Reply 0
Mar 16, 2012 | 05:13 PM
You don't actually have to drop the axle to get the fuel pump, it is tricky, but you can do it by just lowering the exhaust.
Reply 0
Subscribe
