Leaking Anti-Freeze into floorboard
Old Mar 20, 2012 | 09:08 PM
Hopkins's Avatar
When I bought my '91 RS with 87k miles in August it was leaking antifreeze into the passenger floorboard when the car was running. I replaced the heater core about 4-5 months ago and the problem stopped. Now, the problem has started again and is just as bad, if not worse, than it was last time.
What are some outlying problems that could be causing this? Should all of the hoses be replaced? etc.
Thanks for the help!!
Old Mar 20, 2012 | 09:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Leaking Anti-Freeze into floorboard
My guess would be that it blew again since the core itself is the only piece inside that carries any coolant. As you already know, all the hoses & clamps are outside so that only leaves the core itself to leak (again).
Old Mar 21, 2012 | 02:25 PM
Hopkins's Avatar
Is there any reason you can think of why the heater core may be busted again? Could there be something on the outside affecting the heater core and making it leak?
Old Mar 21, 2012 | 03:34 PM
Car: GTA
Other than the hose clamped on & squirting towards the firewall & getting in that way, busted core is all I can think of but then it would be a lot of water compare to where a cure leaks.
Have any trouble getting the new core in & possibly twisted a tube cracking/weakening the welds & causing it to bust? Something they are tricky to line up into both holes so it wouldn't surprise me that much.
Old Mar 21, 2012 | 09:50 PM
roc_racer's Avatar
Car: 1985 IROC
Engine: 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 w/ auburn posi
I had a dare i say it, a mustang that ate heater cores and after about three of them a mechanic told me to hook ground wires to all body parts. hood, trunk exhaust,block,frame. It sounds crazy but it worked and I never changed another heater core. The antifreeze turns to acid somehow and since heatercore is thinner than radiator its the first to go. maybe something to try.
Old Mar 21, 2012 | 09:59 PM
Chadlichte2012's Avatar
Car: 88 Camaro
Engine: 350 .030 over, carbureted
Transmission: T-5 w/Centerforce clutch
Axle/Gears: Haven't checked yet!!!
Def a broken heater core... maybe try an oem part this time?? Also that is true that antifreeze will carry voltage. Test it by placing the positive terminal of a volt meter into the radiator and negative to battery ground.. another good idea is flushing the cooling system with water prior to replacement.
Old Mar 22, 2012 | 02:01 PM
camarojuggalo's Avatar
Car: 1987 Iroc-z
Axle/Gears: 3.73 posi
Make sure you do check your clamps on the heater core cause that will cause antifreeze to spray into the cabin
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
