unidentified broken line & heater hose question
Old Mar 22, 2012 | 03:59 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
The newbe questions begin. Please tell me this isn't a brake line. Saw this was broken and can't even tell where it's suppose to go. pictured are the break and where it leads to from the other end. Passenger side right below the floor board.
The next question is the two lines running into the heater core are stupid hot, hotter than other cars i've delt with, is this normal? I'm guessing those lines don't hit the radiator until after the heat goes through the core? I still need to update my signature on here but it's an 84 camaro with a crate 350 engine in it.
Recently purchased it stupid cheap.
Old Mar 22, 2012 | 04:00 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Re: unidentified broken line & heater hose question
Old Mar 22, 2012 | 04:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
IT's the AIR line they've failed to reconnect when the cat was replaced.
Old Mar 22, 2012 | 04:07 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Thanks!
Old Mar 22, 2012 | 07:20 PM
camarojuggalo's Avatar
Car: 1987 Iroc-z
Axle/Gears: 3.73 posi
The two lines coming out of your heater core are coolent lines and yes there need to be hot sounds like there working fine
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
