hydro flat tappet cam in a rollerblock
Old Apr 5, 2012 | 07:13 PM
Sttn89's Avatar
Car: 89 caprice
Engine: 350 650 dp on roids
Transmission: 700r
can it be done successfully
Old Apr 5, 2012 | 07:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: hydro flat tappet cam in a rollerblock
Yes
but why would you want to backwards to old technology?
The factory put FT cams in roller blocks when they installed them in truck motors ('87 -'95)
Old Apr 5, 2012 | 07:22 PM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
Flat tappets are cheaper and easier to get.its going in a rollerblock but my interest was just in the cam.i dont plan on converting it to a flat tappet i just wanna use the cam,thanks for the fast response
Old Apr 5, 2012 | 07:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You don't use roller lifters on flat tappet cam
If you install a FT cam , you need FT lifters and new longer push rods to suit the shorter FT lifters
Old Apr 5, 2012 | 08:08 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Roller lifters on a flat tappet cam.... It will work, it's just anyone's guess as to how long it will last. May only last a few minutes, may last a few months...
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
Ironhead38
Sep 7, 2015 02:26 PM
TheExaminer
Sep 6, 2015 11:40 PM
