egr delete
Old Apr 9, 2012 | 06:50 PM
lakeport's Avatar
Car: 1988 GTA Trans AM
Transmission: 5 speed
egr delete
i see two different egr delete kit
tpiparts has single plate egr delete
hawks has a 2 plate
which do i need, for a 88 trans am gta, 305 tpi
need to remove the egr as previous owner removed solenoid and egr wiring from harness, and have a code 32
thanks in advance
Old Apr 9, 2012 | 07:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: egr delete
Delete kit only used to make things look purty
Removing the EGR valve will have no effect on the code being shown so you may as well leave it in place.
Getting EGR deleted from the tune will remove the code
Old Apr 10, 2012 | 06:53 AM
lakeport's Avatar
Re: egr delete
OK, really appreciate the quick reply
So I dont need to remove the EGR and block it off? leaving it wont cause any issues, like vacuum issues?
Also if i get a ALDL cable, can i use that to disable EGR in the PROM or do I have to get the PROM reflashed by third party?
Old Apr 10, 2012 | 09:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: egr delete
Not if it is sealing the EGR port correctly
Unless you are taking the TPI intake apart , is easier to leave valve on place and remove vac line to it
You need a custom tune with EGR deleted
Old Apr 10, 2012 | 10:41 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Re: egr delete
Or make one, mines blocked off
Old Apr 11, 2012 | 09:24 AM
lakeport's Avatar
Re: egr delete
Ok so should the EGR be closed or open position, which is correct if vacuum is unhooked?
the previous owner has installed a re-certified ECM and a hypertech chip, can i purchase a add on with EGR disabled and use with this chip? or must it be programmed by third party, if so any one in Canada recommeneded? or can i just disable EGR using a ALDL cable?
sorry for all the questions, really appreciate all the great help
Old Apr 11, 2012 | 11:09 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: egr delete
NO
if working correctly valve should be closed with no vac; vac is what makes it open (obviously )
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
