Distributor question.
Old Apr 16, 2012 | 05:45 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
I have a 1988 camaro 305 and there are two ports on the ignition module. But I only use one of them and only one plug goes to the coil, but there are two plug ins on each, am i missing something here?
Old Apr 16, 2012 | 05:51 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Re: Distributor question.
It's like this but on the port circled is currently used
Old Apr 16, 2012 | 07:15 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Do you have a tachometer that works, might be a connection for that.
Old Apr 16, 2012 | 07:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, missing the pigtail between the coil & ICM. It is two wires, a white and a pink with a connector on each end. Can find them in JY's on Caprices, 3rd gens (6 & 8 cyl, year dependent), and many trucks and vans.
Just look for ones that have the small cap distributor. And grab a couple as the wire tends to break where it exits the coil side connector.
The engine won't run with it missing. It provides power to the ICM and the ground to dwell & fire the coil on the other wire.
RBob.
Old Apr 16, 2012 | 08:05 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
RBob.
Thank you.... probably why my car wont pulse the injectors... thank you so much
Old Apr 17, 2012 | 07:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, that too. Without power the ICM won't send distributor reference pulses (DRPs) to the ECM. Which it needs in order to fire the injectors. The 4-wire connector is the interface between the distributor and ECM.
RBob.
Old Apr 17, 2012 | 01:43 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
RBob.
Thank you so much. I must have lost the old one during the eengine swap. I just made the connections and boom it fixed all my problems. Injectors pulse and car starts. Thank you again so much.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
