Currently I have the stock Serpentine brackets on my Camaro (from a 92 of course) but I'm wanting to switch to an aftermarket set-up because I have no air conditioning or air pump so I am only using the passenger side bracket for the auto belt tensioner. The car is not daily driven, recreational use. The issue I am coming across is that all of the aftermarket (March 22050 and likewise) use a standard rotating pump and I of course have the reverse rotation, also it mentions on many that our power steering pumps were changed (87?) and some kits wouldn't work.
So my question is can I buy something like the March 22050 or 22011 and purchase a long nose standard rotation water pump and be OK with my existing alternator and power steering pump or do I need to switch the power steering pump and alternator too?
Have you thought of using a a/c delete pulley? The factory used them, you should be able to get them at most parts stores.
Quote:
Yes, I have the ac delete pulley. I'm wanting something that looks better and takes up less space.Originally Posted by ex-x-fire
Have you thought of using a a/c delete pulley? The factory used them, you should be able to get them at most parts stores. TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,148 Times in 749 Posts
Just use the dr side bracket and 1 short belt with a custom built alt adjuster.
Quote:
Which would make me ask: Where or how would I get a custom built alternator adjuster? I think it would be far less trouble (and look better) to buy a different water pump and if I had to an alternator/PS pump and an aftermarket kit. The standard chevy water pump/ps pump/alternators seem cheaper and easier to find then the ones I have now.Originally Posted by TTOP350
