FUEL PUMP SWAP????
Old May 1, 2012 | 10:06 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
FUEL PUMP SWAP????
So I got a 84 z28 carbed engine, and I was at the junkyard and took of a fuel pump of a V6 87 RS and I was wondering if I could just use that sending unit on my z28 becuase my sending unit has gone bad.....can I use it or will it not work??thanks!
Old May 1, 2012 | 10:14 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: FUEL PUMP SWAP????
Should work fine. I'd clean it up really good first though and make sure it's in good shape.
Old May 1, 2012 | 10:41 PM
calgutie's Avatar
Car: 1984 Z28
ok thne thanks! and do you know if the pump will work too?or no?do I ahve to get one from a v8?thanks!
......and clean where....just the outside of the sending unit?thanks!
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
