gas gauge acting weird
Old May 9, 2012 | 01:05 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
(this is for my 86 firebird with a 305)
recently i've noticed my gas gauge giving weird readings, it will read empty then if i put the key in the on position it will give a random reading like 1/4 of a tank or full, i know nither of the readings are right because the car is nearly out of gas....
has anyone else had this problem?
Old May 9, 2012 | 07:36 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: gas gauge acting weird
Mine was real bad when somebody hack jobbed a fuel pump job in my car; it always read way above full. Fixed the fuel pump problem and the gauge is better, but not perfect. It fluctuates, and if you give it gas the gauge goes up a bit, reading more full. I have 2 or 3 spare gas gauges that i plan to try to see if they are any different, but im waiting to do thhat until i get a new tach (mines shot). So maybe go to a junkyard a get one for a few bucks and try it. The gauge should work as long as its not pointing straight up or down. (junkyard one) or buy a new one, up to you.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
