Left me sit , towed it , it then started ???
Old May 16, 2012 | 07:21 PM
89GTA_wFact.CD's Avatar
Car: 89 GTA Blk on Blk w/ T's
Engine: 5.7 TPI
I just got my GTA back on the road after 2 years of not being inspected , in those two years it was started and moved on a regular basis.
This past Sunday I took it out for a drive for the first time , stopped and put some gas in it and drove to a local park with a friend to sit and talk. The car sat for maybe 40 min and when we went to leave , I tried to start it and it ran like crap for 10 seconds before I shut it off too try it again , this time it wouldn't start at all , just cranking , tried muiltiable times and opened the hood for a few min to let the heat out thinking that might be it. Didn't work , so i called to have it towed home. On the second day of sitting after all of this , it started with no problems ??
I haven't taken it out yet to see if it happens again.
Any ideas ? ....... fuel pump ? bad gas ? Over heated ? ..... before this any hint of something wrong was it was running rough when heading to our destination.
thanks
Old May 16, 2012 | 07:25 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Left me sit , towed it , it then started ???
Sounds like an ignition module failing. Next time it won't start, check spark. Also, check fuel pressure to be sure the pump and control circuit are okay. If spark is okay and the engine won't start, try unplugging the MAF sensor. If the engine starts in this state, you have a MAF sensor or circuit problem.
Old May 16, 2012 | 07:36 PM
Engine: 5.7 TPI
thanks for the info. , I'll check into it , I hope to find the problem , nothing worse than not knowing if it will start
Old May 20, 2012 | 10:44 PM
Engine: 5.7 TPI
so far the car is running and starting fine , I'm just wondering if the gas started to seperate after sitting in the car for almost 2 years , I've driven the car twice since then and has performed fine ? I also put a bottle of injector cleaner in.
Old May 20, 2012 | 11:24 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I agree with ASE doc. if it does it again check for spark. Those ignition modules are cheap and very prone to intermittent failure modes, especially during the summertime. If you want go buy a parts store replacement one and keep it with you.
Old May 21, 2012 | 01:09 AM
Engine: 5.7 TPI
good idea, thanks
Old May 21, 2012 | 04:45 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
This is an interesting situation. I'm used to seeing heat related failures and even intermittents in the ignition modules, but that your's has been running fine for a little bit is weird. Still could be the module though. However, you might want to throw a fuel filter in it just for drill and check the filter that comes out for heavy contamination. It may have enough crud in it to cause random clogging. Fuel separating isn't something I really see happening. You might also try wiggling the engine harness around the distributor and the MAF sensor just to be sure you don't have a poor connection.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ozz1967
Aug 16, 2015 10:23 PM
