Part Numbers for correct gaskets/orifice tube?
Old May 29, 2012 | 04:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I'm looking to have my A/C system recharged but I need to know which gaskets and orifice tube to buy? I know I've read about the "green" gaskets and the blue ford orifice tube?
I will also be buying a new compressor because mine is starting to squeak really bad.
Car has been retrofitted with a serpentine belt system out of an 88 T/A which included the AC compressor. Otherwise everything else is stock for an 84 T/A.
My A/C worked fine until I shipped the car over here to the UK and now it will run cold for a bit, then blow hot which to me says my system is low/leaking.
I need to know exact p/n because I'm here in England and need to order them online. No one carries that stuff on the shelf over here so I don't want to have to order/return things if I order them wrong. Thanks for your help!
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
