fuel pump? sensor? electrical? need help
Old May 30, 2012 | 06:30 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Hey guys, you name it and it has either been replaced or maintained.
I have a 1986 trans am v8 305 FI Automatic
If i take my car out to run some errands it does not like to be started stopped then restarted.
Meaning if i stop off at a few places usually by the 3rd-4th time i start up my car is doesnt like to start on the first try.
The only thing original is the fuel pump itselft and the internal sensor. its relay and other relays and other connectors have been replaced.
all other sensors have been replaced.
8 injectors have been replaced except for the 9th injector because it is discontinued so mine is original
the car sometimes throws a low voltage code at the fuel pump but this happens maybe once a month if not less and i drive my car daily.
also all replacements or maintenence was to just keep the car going or running prestine. it wasn't always to fix an engine light. It was to avoid engine lights in the future.
Any ideas of where to start troubleshooting?
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
