How to wire second fan to come on with the first
Old Jun 1, 2012 | 06:46 PM
BayAreacustoms's Avatar
Hi,I want a simple way to wire second fan to come on with the first.
1989 iroc 305.thanks
Old Jun 1, 2012 | 07:05 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: How to wire second fan to come on with the first
Cut hot wire to second fan, splice to hot wire for first fan.
Old Jun 1, 2012 | 07:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Wire the two fan relay control terminals together
Old Jun 1, 2012 | 07:10 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Can I ask why? If the car running to hot?
Old Jun 1, 2012 | 07:23 PM
How do i do that? and yes car is running hot and second fan does not come on.I replaced the switch.Where is the second fan relay?
Old Jun 1, 2012 | 07:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by BayAreacustoms
car is running hot ?
how hot is HOT?
More to a circuit than just a switch.
Have you tested the fan motor to see if the fan actually works?
Does fan circuit have power to it , does the relay circuit have power to it , does the relay work ,fuses good , wiring good , grounds good , etc, etc , etc
How do i do that?
both relays should have a green/ white control wire , join those two together , when one relay turns on the other will operate as well
(if everything outlined above is correct and working properly , no amount of rewiring is going to fix something that is broke )
Old Jun 1, 2012 | 07:49 PM
Thanks, everything checks out good,put power to fan and it works.It gets to about 250 right below red mark
Old Jun 1, 2012 | 07:54 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Is the air dam under the car in good condition? Theres really no need to have both fans ok all the time.
Did you change anything? Run low on coolant and have an air bubble trapped in the system now?
Thermostat stuck shut? Id trouble shoot the problem before trying to bandaid it with both fans on at once.
Old Jun 1, 2012 | 08:31 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is temp gauge working correctly?
Have you separately confirmed that the engine is actually at the temp shown on the gauge ?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
