1984 Firebird Cant star car with ignition cylinder
Old Jun 9, 2012 | 08:39 PM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
My car wont start with the keys. I installed a new cylinder and ignition switch. I have power and everything works and i can start car by putting a screwdriver on starter! I just cant start car by turning key
Old Jun 9, 2012 | 08:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1984 Firebird Cant star car with ignition cylinder
Do you have 12V on the yellow starter wire at the Ign switch when in START position?
Is the switch position adjusted correctly?
Old Jun 9, 2012 | 08:51 PM
Engine: LT-1
Yes theres 12v and it adjusted right. I know that because on the factory one when i turned key oil pressure gauge will jump and now on the new one same thing oil pressure gauge jumps when trying to start.
Old Jun 9, 2012 | 10:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I know that because when i turned key oil pressure gauge will jump
OP gauge has nothing to do with starter circuit;
the fact it moves when you go to start probably means you have other wiring problems
Have you actually measured for 12V out at the switch???
So if you have 12V on the starter circuit at Ign switch and nothing at starter solenoid
you have a break in the wiring between the two
Old Jun 9, 2012 | 10:42 PM
Engine: LT-1
I have 12v at the switch but havent check the starter. as of right now i wired in a darn lightswitch to start it. you know flip up then flip down so starter wont spin. i will check out all the wiring tomorrow.
Old Oct 29, 2012 | 10:10 PM
Engine: LT-1
Fixed this problem a long time ago. i put a new ignition switch along with new cylinder and neautral safety switch. It was only my neautral safety switch -_-
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
