will any 5.7 work need to know asap
Old Jun 23, 2012 | 07:38 PM
jhp73's Avatar
Car: 1987 iroc Z-28 5.7 TPI
Engine: 5.7 TPI
I have an 1987 iroc 5.7 tpi. I am going to have to buy a new 5.7 long block so I was wonder will any 350 long block work with a Tpi system. Thanks a bunch need to know asap cause I got a line on a blueprinted long block
Old Jun 23, 2012 | 08:13 PM
platynumx's Avatar
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
Re: will any 5.7 work need to know asap
if you elongate the intake holes it should .if you dont wanna elongate intake holes get a 350 with 1986+heads (the centerbolt valve cover style) i m assuming your talking about that 87 listed under your name.
Old Jun 24, 2012 | 01:57 AM
jhp73's Avatar
Engine: 5.7 TPI
Yep that's the one thank you for the in put. ya I had it sold and the next day it spun a rod bearing couldn't believe it I had had no trouble with it at all until then.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
dutch930
Sep 11, 2015 06:58 AM
jharrison5
Aug 19, 2015 05:53 PM
