406 help
Old Jul 2, 2012 | 12:36 AM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
406 help
Hey guys, I am need some different oppinions here. I have a 406 that I am having trouble with. It sounds like it has a miss. I have ran compression test and all cylinders but number 1 had 175 compression. At first number 1 had none, "the motor was built than sat for a few months". So we did a leak down and the exhaust valve had 40% leak down. I tapped it and it built up and now all cylinders have 2% or less leak down. The motor runs better but it still sounds like its backfiring through the intake? I have readjusted the valves, checked plugs, look for burnt wires, checked timing, retorques the intake manifold. I'm stumped. Also the car only has 5 inches of vacuum and fluctuates rapidly and comp says it should have around 12 inches. Here is the specs.
406
comp xe288 cam 236/242 at .050 hydraulic
holley 750 double pumper
Msd pro billet distributor
streetfire wires
harland sharp 1.6 rockers
dart iron eagle 215 heads had ported/valve job
motor should be 10.4:1
700r4 with 3000 bdr converter
any suggestions would be appreciated. The motor just runs awful when under aload, but in idle or just reving it sounds fine.
Old Jul 2, 2012 | 12:59 AM
thirdchance's Avatar
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Re: 406 help
What was your valve to piston clearance?
Old Jul 2, 2012 | 09:22 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 406 help
Ran into that once
Wires on cyl 2 and 4 were reversed. Coulda fooled me!
Old Jul 3, 2012 | 11:06 AM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Re: 406 help
Well, I checked all the wires and all were good except number six. Started it up and same thing. So took the intake off and checked it. It was warped pretty good. Took the coating off and tried it and same thing . We set the valve to zero and started it, run perfect steady 12 inches. So, I guess the second set of lifters from comp are no good.
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
