TPI Fuel Pump?
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
TPI Fuel Pump?
I have an 83 CFI and I recently replaced the fuel pump. I was trying to get my fuel pressure to 14 or 15 psi, but even with the regulator at max, I am only at 13 psi. I'm guessing the fuel pump cant provide any more pressure? (Bosch 69237) I couldnt find any info on it regarding max psi.
I was wondering if running the pump at max psi would shorten its life and if i should just swap a TPI fuel pump now?
Thanks in advance
Thanks in advance
Car: 82 Z-28
Engine: 383 TPI
Re: TPI Fuel Pump?
It has been a long time since I checked fuel press on a CFI but aren't they supposed to be like 11.5 or 12 psi?
I do remember they're very sensitive abt the press being set right on the money..
Not sure what you're trying to do, but 14-15 sounds too high for a CFI.
Car: 1983 Trans Am
Engine: Lu5
Re: TPI Fuel Pump?
The factory setting is supposed to be from 9-12 psi but a lot of the CFI guys on this site suggest 13-15 psi. I have 13 psi but I'm not sure if the pump will last running at max?
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
