NEED HELP TPI SWAP FIRST TIMER! harness
Old Jul 12, 2012 | 11:00 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
hello I'm doing tpi swap its a 89 rs with 92 lo3, I have just swap those 187 heads for some 081 and also added a lt1 cam... the car i got the parts from was a g92..
well i got all the harness in except for a few wires ... all my power worked and my engine turned.. no fuel pump prime...
the people who owned my car before me hooked the fan up direct to run with the key on, i cut the fuse off the tpi harness and spliced mine into it but there is an extra orange wire and i also have an extra red wire???
as for the fan, there is an extra orange and black with purple stripe wire on the passenger side ...
Attached Thumbnails NEED HELP TPI SWAP FIRST TIMER! harness-imag0011.jpg   NEED HELP TPI SWAP FIRST TIMER! harness-imag0012.jpg
Old Jul 13, 2012 | 01:21 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: NEED HELP TPI SWAP FIRST TIMER! harness
Originally Posted by Chris_89rs
no fuel pump prime....
Have you got a pump relay installed?
Does relay have power?
Is oil pressure switch for the pump installed?
Can you bypass the relay to make the pump work?
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
