tps sensor
Old Jul 18, 2012 | 06:42 PM
ssbsh21's Avatar
Car: 1986 camaro iroc z, 2001 Isuzu troo
Transmission: auto
tps sensor
Ok so my car stalls when I hit the gas pedal, I fixed the gas leak and made sure everything was clean. I got advice to check tps sensor and how to check it. I hooked it up to meter and here is what it does. With the plug unhooked it reads a stable reading but as soon as I plug it in to the sensor the meter jumps off the charts and stays there and hitting the gas doesnt change anything. Is that bad?
Old Jul 20, 2012 | 09:45 AM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Re: tps sensor
Something doesn't sound right; throttle close should be around 0.54, WOT should be around 5. Double check to make sure that you're testing the correct wires (no offense) and if you are, it sounds like the TPS is shot.
https://www.thirdgen.org/forums/tpi/651287-tps-sensor-voltage-bad.html
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
