fuel pump ground????
Old Jul 25, 2012 | 06:48 AM
acechase99's Avatar
where is the ground at the fuel pump located im trying to use this http://members.shaw.ca/corvette86/Code%2054.pdf to find out why my pump is not priming
Old Jul 25, 2012 | 10:21 AM
Zig's Avatar
Zig
Car: 91 Z28 with 64,000 miles
Re: fuel pump ground????
What year and engine? On my 91 8 Code 5.7 it's the black wire from the sending unit. Connector plugs into the bulkhead connector forward of the fuel tank. Not sure where the actual ground is connected from there but a quick ohm check would tell you if it's a good ground.
Old Jul 25, 2012 | 11:11 AM
acechase99's Avatar
ok i believe mine is the same its 89 firebird 5.7 TPI im trying to tack down why my pump wont prime its new fuel pump among other parts i prob it with a noid light and get nothing at the tan wire and a very weak light at the pink wire. you dont happen to know where i can find the fuel system curcuit layout do you. what setting sould i have the ohm meter on and what should it read.. me and volt meters are like fat kids and broccli
Old Jul 26, 2012 | 06:52 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I don't trust ohm readings when testing for poor connections. You can get a low reading on a circuit and have the same circuit drop voltage when it's placed under a load. I use the voltage drop test. Simply place one lead at one end of the circuit and the other lead at the other end. Since the circuit is supposed to have no resistance in it, there should be no voltage reading from one end to the other. In reality, you may see .2 volts from end to end on either the positive side or the ground side, when the pump is running. If you see more than 1 volt, you have a definite poor connection somewhere in that circuit. You can then break the circuit up into sections and test each one to pinpoint the bad connection.
Old Jul 26, 2012 | 09:56 PM
acechase99's Avatar
thanks to Zig we managed to find out the guy before wired the fuel pump connectors wrong so car is fixed and going to be legal next week i hope
thanks everyone for the help
Old Jul 26, 2012 | 10:50 PM
Zig's Avatar
Zig
Glad I could help. If we could just get the hackers to stop mutilating the wiring harnesses, we would all have a few less headaches...
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
