Fuel Pump guidence...
Old Jul 31, 2012 | 05:18 PM
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
My L98 TPI rests in an 86' K5 Blazer. I didnt do the swap and my guess is the fuel pump was not replaced at the same time. Original motor was a carb'd 305.
Im planing a suspension mod here shortly that requires me to drop the tank. I figure I may as well install the right fuel pump while Im at it.
FYI: the motor has a leaky rear main seal so Its going to be pulled this winter. At that time it will go through a mild re-build: Vortec heads, cam, SD manifold and large runners new injectors and 52mm TB (funds permitting a 383 kit).
Any recommendations on a fuel pump for that set up?
Attached Thumbnails Fuel Pump guidence...-user1803_pic1966_1340695970.jpg   Fuel Pump guidence...-user1803_pic2004_1341867114.jpg
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
