Vapor Lock Please Help
Old Aug 12, 2012 | 02:41 PM
SBC84's Avatar
I have an 84 Z-28 and I am having a vapor lock issue. It has a 350 bored .30 over and a mild cam. it has a mechanical fuel pump. the car is vapor locking on me and i cannot figure out how to fix it. it doesnt happen all the time but it will every once in a while. the little glass fuel filter was showing nothing but bubbles!! Its pretty bad and any input would be nice.
Old Aug 12, 2012 | 06:05 PM
L98IROCZ1987's Avatar
Car: 1987 IROC-Z Z28
Axle/Gears: 3.70 9 bolt
Re: Vapor Lock Please Help
What is the fuel pressure
Old Aug 12, 2012 | 06:34 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
The factory setup uses a return fuel pump. That right there should have the problem fixed.
If that doesn't your next step would be to add a small spacer between the carb and intake.
Old Aug 12, 2012 | 06:56 PM
Do away with the mechanical fuel pump and install an electric low pressure in line fuel pump
Old Aug 12, 2012 | 06:57 PM
You can get a fuel pump block off plate to replace your pump
Old Aug 12, 2012 | 10:32 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm assuming you have a carb because of the mechanical fuel pump, yes?
You need to confirm two things before doing anything else.
1. Fuel pump pressure - should be around 8psi or thereabouts.
2. Fuel pump volume - should fill a pint can in about 30 seconds at idle.
Check your service manual for the actual test specs.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
