help
Old Aug 30, 2012 | 04:40 AM
sergio1310's Avatar
Car: 87 iroc 5.7 tpi
help
87 iroc wont start just changed the fuel pump n still no start,,, it turns on then goes back off... n e ideas??? wat major sensors should i checkk or n e thinh help plz
Old Aug 30, 2012 | 04:46 AM
sergio1310's Avatar
Re: 87 iroc turns on n right back off helpp
87 iroc turns on n right back off n thats only cuz i spray starting fluid,,, n e ideas??? last week got a new pump so that cant be... wat major sensors r there to check,,, do the fuel relay has a somethoing to do with the car not staying on??? mines a lil burned,, wat to do help plz
Old Aug 30, 2012 | 08:23 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Replace that relay if its burnt. Check fuel pressure. If it runs with starting fluid that means its not getting enough fuel.
