GM headgasket 10105117 - which way is "up"
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
bought these to go back up with my rebuild of the top end, but there is no specific direction of which side is "up". i assume the side that has the part number on it would be the "up" side, but would like to confirm if somebody knows first-hand. planning on installing tomorrow... thx...
Re: GM headgasket 10105117 - which way is "up"
Yes installed text should be readable, the dimpled side goes down
quadgoat
May 2, 2004 12:15 PM
10105117, 1986, coated, forum, gasket, gm, head, headgasket, installation, instructions, lb9, number, part, side, top
