100k maintenance?
Old Sep 19, 2012 | 01:32 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
100k maintenance?
I've messed with my suspension and steering a lot so it's all either new or going to be new; however, I have hardly touched my engine or the rest of the drivetrain other than air and oil filters, the PCV valve and engine oil changes every 3k. The car was taken off daily driver duty in June after 2 years and 20k trouble free miles. However, it's about 4.5k from rolling its first 100k. I figure on doing plugs and wires, and maybe dropping the tranny pan and changing fluid and filter.
Anything else you guys recommend replacing, refurbishing or changing at this milestone? Thanks!
Old Sep 19, 2012 | 03:35 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Re: 100k maintenance?
While you're tackling the trans you could check your rear end to see if the pinion seal is leaking and change the fluid back there too.
Old Sep 19, 2012 | 04:15 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
check your front and back sway bar bushing. Check tierod ends and ball joints. Check or change tranny fluid. How's belts and hoses?
djmarch
May 8, 2016 11:32 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
GTAman
Sep 21, 2015 09:57 AM
