Serpentine pulleys
Old Sep 27, 2012 | 10:51 PM
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Transmission: Tremic 6 Speed
Axle/Gears: 3:43 posi
Serpentine pulleys
Is there a serpentine pulley swap I can do for the either the crank or water pump to slow the revs down? We are running the engine at high revs for a long time in the endurance races.
Thanks for the help
Old Sep 28, 2012 | 05:54 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Serpentine pulleys
try jones racing products
Old Sep 28, 2012 | 07:04 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
pop hoods on cars and trucks in junkyards.. you want a smaller crank and/or larger water pump pulley.. you can generally mix and match, but there are some differences in how far the belt is spaced out from the front of the block from application to application.
Old Sep 28, 2012 | 01:11 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have the OLD SLP small crank and huge alternator pulleys. I don't use the alt pully because it will not charge on the street at all, so I just use the crank pulley..
I'm keeping the Alt pulley tho..
jrdturbo
Mar 31, 2016 02:58 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
