Will this fuel pump work ?
Old Oct 5, 2012 | 03:01 PM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
its a 1985 Iroc-z. H.0. 4bbl Carb.. I been looking for a stock fuel pump in the back and it looks like this
http://s1175.photobucket.com/albums/...ent=jklklk.jpg
http://s1175.photobucket.com/albums/...t%3Dphoto3.jpg
- The only problem is, acording GM AC-Delco Discontinued this product. they only make the high pressured pumps for the TPI's. I talked with a couple people and they asked me to try one of these two.
http://shop.advanceautoparts.com/web...d=1#fragment-2
http://www.summitracing.com/parts/VPN-5CA401-1/
From your point of veiw what would you use. one is from walbro in the above link, which the person i talked to said it was for tbi and that it pushed out low pressure like mine up to the mechanical fuel pump.. I mean Idk, u think that **** would work 4 ma car
Old Oct 5, 2012 | 06:44 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Re: Will this fuel pump work ?
Well I would just got with the walbro becuase if you are running a stock car with no real mods you dont need the high pressure pump.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
